SCVJeff
Dec 22, 2014Explorer
firemedic1992 wrote:The amplifier is in the antenna itself; both the Batwing and the Jack, and neither will work without it (meaning if I'm reading this correct, the Batwing is likely still good). As it sounds you've discovered that the wall plate is simply a DC power inserter into the coax. IF the coil on the wall plate is burned up, it can be replaced, OR you can use the Sensar Pro which is an excellent device and solves several other problems with RF distribution and locating ATSC stations.
I replaced my old antenna with a King HD TV antenna, but could not get it to work. After troubleshooting it, I found that the amplifier was dead. What should I replace it with?
I was thinking of the Winegard Sensar Pro. Is that a good choice?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
