wa8yxm
Dec 22, 2014Explorer III
firemedic1992 wrote:
I replaced my old antenna with a King HD TV antenna, but could not get it to work. After troubleshooting it, I found that the amplifier was dead. What should I replace it with?
I was thinking of the Winegard Sensar Pro. Is that a good choice?
The Sensar Pro is an excellent unit.... I have one and love it.
Now; one fault: you said "The amplifier is dead"... You tossed the amp in the trash with the rest of the old Batwing,, What you have inside is only a power supply and switich (At least in most cases)
The Sensar Pro, however *IS* an amplifier, as well as a power supply for the "Mast head" amp (Same as the old wall plate) and a switch, and a scanner, and a signal meter and... well you get the idea.. Very nice and handy
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
