firemedic1992's avatar
Dec 22, 2014
TV antenna amplifier replacement
I replaced my old antenna with a King HD TV antenna, but could not get it to work. After troubleshooting it, I found that the amplifier was dead. What should I replace it with?
I was thinking of the Winegard Sensar Pro. Is that a good choice?
  • I did check using a voltmeter and no power was getting to the head. Once I disconnected the coax from the wall amplifier and used the new in-line amplifier supplied with the new antenna, it worked.
  • Yes, the Sensar would be a good replacement, however you should get the wingman to go along with it.
    You may want to consider the Jack antenna.
    Jack antenna
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
