SUKISHORTExplorerNov 10, 2014TV InterferenceI have my bedroom tv hooked up to the wiring for my outside antenna. When the heater come on there is a lot of interference. Anyone had this problem.
4 RepliesReplies sorted by Newestn7bsnExplorerNov 11, 2014Is it just the bedroom TV? If so the problem might be in the TV, low shielding for interference.wa8yxmExplorer IIINov 11, 2014I can not improve on the advice above.Your outside antenna (if Winegard or Jack) runs on DC, low voltage can bother it, as it can the TV. But dirty brushes make radio hash, Take an AM radio and hold it near the furnace motor when it's running, you will hear what I mean.Also the Direct Spark Ignition, will mess it up, but that should clear within 4 seconds.YC_1NomadNov 11, 2014Find every connection and tighten them to start. Is your television running on DC or AC?MrWizardModeratorNov 10, 2014dirty brushes on the heater/furnace blower motordo you have a battery connected ?a good battery can filter this kind of noise, by absorbing it
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
Related ContentTV Interferencetv interferencetv interferenceRF Interference from LED Lights affecting TV?converter interference
