Matt_Colie
Nov 24, 2014Explorer II
CG,
The explanation is actually simple if I can make it understood.....
When you crank the genset (APU) in pulls the bank voltage down. Now, the simple part is that the audio part of the set is simpler that the video. The video actually is a computer that assembles the picture, and when the voltage dips too low, that computer's program loses its place and needs to be restarted. The problem comes that the boot-up routine is trigger by the set sensing "Power On", and, as it didn't power on, the re-boot doesn't happen. TVs aren't the only things with this problem.
Matt
Matt
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
