My TV in the bed room near the amp works well ! The one in the living room 10 ft away no so good .The bed room may get 10 channels the other if your lucky 3 .Any help wood be appreciated !
Make sure the settings of the tv are correct. You can set it for antenna or cable input (in your case it would be antenna) and then have it search for channels. If you're still not getting all the channels then it may be the wiring between the amp and the tv, loose or dirty connection or broken wire.
And some TVs just aren't good at picking up weak signals from some channels. If both TVs are the same model you should get the same reception on both.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
