My TV in the bed room near the amp works well ! The one in the living room 10 ft away no so good .The bed room may get 10 channels the other if your lucky 3 .Any help wood be appreciated !
Different televisions work better than others too when plugged into the exact same wire. Try running a wire directly from the jack nearest the power booster to the television farthest away. Then use the same wire and plug into the television closest (with the same wire). If they are different, it's because of the television and nothing happening with your camper or the wires. Test it!
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
