ford truck guy wrote:
What if you do not have a wall plate ?? where would the sensor pro go then ?We have a Winegard entertainment center with the booster built in..
This is a very easy setup.  Just get the video controller out so you can see the back.  The 12V power that goes into the controller will be moved to the Sensar Pro.  You remove the coax from the back of the video controller that says TV antenna and connect it to the Antenna connection on the Sensar Pro.  You then run a jumper from the Ant. 1 (or 2) connection on the Sensar Pro back into the controller where you removed the coax.  That's it, you are done.
If the video controller also has a connection for a DVD (Red/White/Yellow) that you use you need to leave 12V power going to that controller and you just jump the 12V from that connection to the Sensar Pro.
