HMS_Beagle
Nov 12, 2014Explorer
They should be the same chemistry (like flooded or AGM or GEL). Preferably they should be the same brand (because even flooded chemistries will differ a little between brands). They should be the same age (because charge/discharge characteristics will change with age). Of those the first one is the only one I would really worry about.
Switching banks used to be the normal, however since the life of the battery bank is non-linear with depth of discharge (deeper discharge = shorter life) the consensus now is to parallel them into one large bank for longest life.
I would consider putting fuses at each end of the connecting cable. Either end can source fire starting currents if the other end gets loose....
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
