naturist
Nov 13, 2014Nomad II
If you plan to charge them off the same charger or to use them together at the same time, they also will need to connect to the charger/house system with the same length/same size cable. If the cable to the new batteries is a different length, the batteries on the longer cable will never charge fully, and will discharge to a different depth than the originals, which will cause problems down the road. From the sounds of it, you will have to do the switchover thing.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
