HMS_Beagle
Nov 13, 2014Explorer
MaestroPNW wrote:HMS Beagle wrote:
The correct way to wire them is to run cables between the terminals of the two banks, then take the positive power bus cable to one bank, and the negative cable to the other. Since the current from either (and both) banks goes through these wires, any voltage drop due to them is seen by both battery banks and they will charge and discharge at the same rate (or at least, at rates not influenced by the wiring).
This makes sense, but likely not going to happen in my setup - the second bank will be plugged in through an Anderson connector and be on the outside of the camper. Modifying the wiring in the way that it would hook up to the "remote" bank and be able to unplug it is probably possible but complicated.
Still easy enough: I would run the power bus ground to the in-camper battery. An Anderson connector runs + and - to the in-bed battery bank. A second Anderson connects the returning + to the power bus. When the in-bed bank is not used, both are disconnected, the second Anderson is plugged into the first, connecting bus + to in-bed +.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
