BFL13's avatar
BFL13
Explorer II
Nov 05, 2017
Two Battery Banks, One Trimetric
This may be a useful idea for some, who knows?
I have two separate battery banks in the Class C, and want a Trimetric for each of them. But I only need one at a time. I already have one Trimetric. Costs too much money to get a second. Needs a work around.
I got a wiring kit for 4-pin towing and already had another 4-pin connector doing nothing. The Trimetric wire was miles long so I cut some off to use with the second set-up, and bought an extra 500a shunt for $35.
You guessed it! I cut off some wire coming out of the Trimetric display and added a 4- pin connector to that. Now I have the two wires one from each shunt. I put an opposite-end version of the 4-pin on each of the two wires from their shunts. I marked one of these for which battery bank it is from.
So now all I have to do is pick a battery bank and plug that one's 4-pin into the display's 4-pin. ( I do not use the Tri for history and all that--just as a voltmeter, ammeter, and AH counter.)
I only need the Tri for one of the banks (the AGM bank) for the ammeter when at home recharging the AGM bank to full. But then I really need it on those AGMs. (The AGMS are just for the inverter and I don't need the Tri on that bank while camping--the voltage shows on the inverter.)
When camping, I have the Tri on the main bank that runs the rest of the rig to use it as normal--AH counter, ammeter, voltmeter. In particular for doing 50-90 recharges to see when I am at 90 and can shut down the recharge.
So the Tri is left on the main bank most of the time, but I can swap over to check the AGM bank easily and don't need two displays.
The wire from the display goes down the wall under a metal cover so it looks neat, and all the ugly 4-pin stuff is under one of the dinette seats where the converter and water pump etc is hiding, so it is all out of sight, but easy to get at.
(I do know about the various eBay type monitors available, but this is how I chose to do it.) No idea if anybody else would do this, but there it is.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
