wa8yxm
Oct 23, 2023Explorer III
TurnThePage wrote:
On a side note, do people put pink stuff in the black tank rinse port? Actually I think I'll just push a little air through it.
I'm a fan of air... how I did it
I have a 6 gallon compressor 150 PSI tank set regulator to about 50-60 and blow with all valves including low point open.. Blow till it runs out of air. Drain water heater and bypass. Power cycle the ice maker if any to drain back it's lines MUST HAVE POWER TO DO THAT manually force the cycle.
Now after the compressor shuts off (Full tank) Blow again. like 10 times. There is not much water left even if it pools it wont' be enough to cause damage.. and if the air ever freezes you won't worry about the RV.
IF those QC's come STRAIGHT OUT -- THey won't have enough water in e'm to damage.. If they are slanted \\ Perhaps but most come straight out. BE SURE To open the valves for the outside shower or any valve assoicated with the QCs. (Quick Connects).
You are sure they are both Fresh Water hookups. not propane?
