Cptnvideo's avatar
Oct 31, 2022
Two inverters for 50 amp service
We have a Go Power IC Series 3000 watt inverter and 50 amp service on our 5th wheel. I have 2 complaints about it that I wasn't aware of when it was installed.
The monitor panel only monitors Line 1. The current limit function only limits current on Line 1. So when plugged into a relative's 15 or 20 amp service, we can only see and control what is being drawn on Line 1. And I would like to control the current on both lines so we wouldn't inadvertently trip the breaker feeding the RV.
Is it possible to have two 2000 watt inverters (one on each line)? My dealer says no. But I don't see why not as nothing in the RV runs on 240 volts.
Correct me if I'm wrong, but to create 240 VAC for two 120 VAC lines, the 2 lines have to be out of phase. And if the lines were in phase, 0 VAC would be measured across the 2 lines. So the output of the 2 inverters would be out of phase when plugged into a 50 amp service and in phase when plugged into 30 (or less) amp service. But I don't see an issue with that. Am I missing something?
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 01, 2025
