Like2Travel
Aug 04, 2013Explorer
pianotuna wrote:
Hi,
Check the date code on the batteries. Check the specific gravity with a temperature compensated hydrometer when you believe the batteries have finished charging. The initial charge may take up to 168 hours.
I have looked at what is stamped on the two batteries. Both have the same code stamped on top close to the positive terminal. The code is '2A141D1'. I don't understand the code. Can you help?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
