RedG
Jun 27, 2013Explorer
SaltiDawg wrote:wildwest450 wrote:
It doesn't make sense that it's part of a "string" because it's the farthest light away from all other lights. The wires definitely come from the direction of the fuse box, but continue no further than the light. The other bathroom light has a single wire that come in from another direction.
Farthest geographically may not mean farthest electrically. Separate the whites and separate the blacks and see if both whites are hot - if not, it would seem to indicate the connection is simply passing power thru in a chain.
I have zero RV knowledge or experience, I was just trying to suggest some possible help.
White wires are ground. The black wires should be hot.
