Fortkentdad
Jul 25, 2014Explorer
The trailer's been on battery power all week without any charging. Checked the volts 12.58. Hooked up the two 40 watt panels this evening - going to give it 24 hours and check again tomorrow evening and see what the volts reads. The trailer is sitting idle so only the minimum power draw of the CO monitor and TV/Stereo ready setting. (I'm thinking that it might be wise to pull the fuse on the TV/Stereo when not in use as it does draw something and does nothing - how much does that standby status on a stereo system with TV draw anyway???) Does anything else draw power when not in use? No lights on, fridge is turned off, water heater off, tank heaters off, water pump off.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
