GMT830
May 26, 2013Explorer
Two way fridge on DC?
Our Dometic fridge is a two way.  It works perfectly on 110 VAC, and is well insulated.  We towed without power for about two hours.  Everything was still nice and cold or frozen solid. But it was cloudy and 55 degrees or so.  The previous owner said he spent several hundred dollars having the fridge repaired.  I tried once last year to run it on propane with no luck.  The selector switch does not have a solid feel at all. I would prefer to leave it alone at this point, maybe fool with it again in the fall.  If it needs repair it would be easier to deal with at the end of the season.
So I'm considering running an inverter to power the fridge while traveling. Anyone done this? Any suggestions?
