DrewE
Apr 06, 2016Explorer III
jayspi wrote:dcg9381 wrote:
Thanks for that link.
OP: You're running 6v batteries in series. Your battery connections need to at least match your output, so 6ga is right. 4ga is fine.
If you use that inverter, you'll have to go to 2ga, so something to consider for now.
I, like others, use a real battery disconnect unless you've got the holy-grail of RVs with no parasitic draw.
We'll, I already got the inverter. Are you saying that I'll need to 2 gauge for the series/parallel cables (4 cables)? Or for the cables back to the RV as well (6 cables)? If so that's not a problem, I guess I'll have to order them though. I can't find anyone local who has 2 gauge.
The series/parallel cables should be 2 gauge, as should the wires to the inverter. If there are separate wires going to other things in the RV, they only need to be sized (and fused or protected with circuit breakers) for the current that they would be carrying; 4 or 6 gauge to the DC distribution panel and converter might be acceptable, depending on their length and the size of the house loads and so forth.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
