time2roll
Feb 19, 2019Nomad
I assume you would know if it was black. Either way you need access.
Assuming tank is black ABS plastic I recommend Plasti-Mend to make the repair. Amazon or buy direct. If the crack is large plasti-mend has sheet ABS to reinforce the repair.
Good luck doing this on the road. Maybe some eternabond tape could make a temporary repair.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
