- trailriderExplorerThis is what you want. It sticks perfect on the underbelly.
https://www.amazon.com/Surface-Shields-BP4180-Shield-Repair/dp/B002SSGAZG - mobeewanExplorerThe OP is talking about the black woven tarp like moisture barrier that is used to cover the entire under belly of most 3 season trailers.
- DBH_MIExplorerEternabond or Flex Seal tape both work exceptionally well on coroplast.
- Dave_H_MExplorer III have had limited to decent results with the gorilla.
However the only way to get a good stick is clean the underbelly area good with something like alcohol or lacquer thinner. Put the tape on and then follow up with the DW's hair drier for the final stick. - MEXICOWANDERERExplorerHow about GAFFER'S TAPE?
- ScottGNomad
newman fulltimer wrote:
Go to a mobile home dealer ask for a roll of belly tape its about 25.00 and once stuck it won't come off
If you mean the tape for designed for use on rodent barrier, it's terrible. It will fall off in short order and doesn't stick worth a krap. Companies that do that kind of work use patches made of the rodent barrier and stick it down with 3M aerosol adhesive.
Sorry but the tape is useless. - newman_fulltimeExplorer IIGo to a mobile home dealer ask for a roll of belly tape its about 25.00 and once stuck it won't come off
- filrupmarkExplorer
DutchmenSport wrote:
If you want something that will last forever under any conditions, get a roll of High Temperature Flue Tape. It's the silver colored tape that is used on aluminum vents for furnaces and gas water heaters. The stuff so so strong, it will never give, under any conditions. Caution... you have only 1 chance to stick it on and it cannot be redone. So get it right the first time. Extremely strong stuff and extremely resilient to all kinds of weather conditions.
That's what I use Dutchman Sport is correct - BarneySExplorer IIIMoved to Tech Issues forum from DIY.
- DutchmenSportExplorerIf you want something that will last forever under any conditions, get a roll of High Temperature Flue Tape. It's the silver colored tape that is used on aluminum vents for furnaces and gas water heaters. The stuff so so strong, it will never give, under any conditions. Caution... you have only 1 chance to stick it on and it cannot be redone. So get it right the first time. Extremely strong stuff and extremely resilient to all kinds of weather conditions.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
