RoyB
Mar 22, 2017Explorer III
Here is what I have been doing since around 2009 in my off-road POPUP trailer...
I have this home made BATTERY MONITOR panel that has two 12VDC meter and one 0-70A DC Current meter in it. The two 12VDC monitors each of my two battery groups... Of course when both are selected then these two 12VDC meters read the same...
Roy's image
I have this installed in a good spot so I can get a quick glance at what is going on. These are not absolute reading bit gives an idea what my batteries are doing...
Roy's image
This is my three working GP24 85AH batteries on the tongue of my POPUP Trailer. I lost one GP24 batteries just a few months after settin up this system using my OEM single mode converter/charger and it boiled out the fluids and ruined one of the GP24 batteries. I had four each originally..
Roy's image
I usually see around 24-25ADC on the Current Meter running from 6PM to 11PM each evening which varies up and down of course when we are camping off-grid somewhere and running the things we want to run before going to bed each night. My DC voltmeters usually starts out in the 12.6-7VDC range and slowly drops down as the evening goes on...
Again these are not absolute scientific numbers but just gives me a good clue as what is happening. When these numbers get down to around the 12.0VDC range then I know I am somewhat close to the 50% state of charge.
This usually happens around 8AMP the next morning and this is when I want to run my 2KW generator when allowed to run my on-board PD9260C 60A converter/charger unit. This will bring my battery banks back up to their 90% charge state in around three hours of generator run time. This is also the time we run a few of the high wattage things like making coffee for the day and cooking things etc...
Like said this is our somewhat normal experience when camping off-grid for three or days at a time... Each evening I want to start out with my batteries up at least to their 90% charge state as from experience I have found out they will produce a good 99% of their rated performance and I can can make it just fine to the next 8AM generator run time period. I have found out I can do around 12-14 of these 50% to 90% charge cycles before my battery banks start dropping off on performance. This meaning they start dropping the 12VDC voltage reading quicker each evening... Since it takes around 12 hours or so to get get the battery banks up to the 100% charge state using the smart mode chargers I will only camp out for a week or so and the 12 hour charging run when I get back home. In my case I doubt the camp ground would allow me to run my generator that long at one time.
Adding solar for me will reduce my generator run time back to around 30 minutes to an hour when I notice the DC charging from my 60A PD9260C has tapered back to around 6-8AMPS DC current. My Dc CURRENT meter will show a NEGATIVE symbol when we are pulling amps from the batteries and will read not show any symbol when we are putting DC amps back into the battery banks.
I started to go through all the math like you are doing and it really didn't make a whole lot of sense to me so after running a few days and nights in my backyard setup doing exactly what I probably would normally do at the camp site meant more to me than having the exact numbers and college answers etc...
I have done good with my old GP24 12VDC batteries until just last season when they really started dropping off on performance. This was just using three of the GP24 85AH 12VDC batteries in parallel giving me something like 255AHs of capacity...
I am currently working on a new battery bank with two groups of GC2 6V batteries in series that should give me around 450AHs of capacity. I may just alternate groups each night with this setup...
This is what I have been doing since 2009 with my setup... These are the things I went through getting my battery system up and going for my style of camping off grid...
Roy Ken
Roy's image
Roy's image
Roy's image
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
