time2roll
Mar 22, 2017Nomad
Shade and solar just do not work.
Yes capacity will drag down a bit every day that partial charge is made. The lower the stopping point the worse it will be. PMB is great when plugged in. I think you need something different for charging on generator. IOTA or Progressive Dynamics. Could get a manually controlled PowerMax but that is not my style. Maybe a separate 30 to 45 amp converter to do the finish charge to 90+ percent.
9245-14.8 Get 60 or 70 amp if it will replace the PMB75. Get the 80 if you expand to 4x GC2. Actually 80 is good with any combo but could be overkill.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
