Eduardo333
May 30, 2017Explorer
So, just to establish. I flipped all the breakers off except the main ones. There was no change throughout and the 160 watt draw continued. Also I understood that most of the ghost loads mentioned are running off the 12 volt, and I thought that disconnecting the converter separated it from the 120. Should note that I have already put the batteries on a solar charge directly. I have tested to see what was running off the 12 volt by disconnecting the 120 and found that the pump, antenna booster and water heater continue to function. I'm not sure if the refrigerator does, but believe that it was.
