TomG2's avatar
TomG2
Unplug or Kill Generator first?
Not into any kind of brand argument. Simply this, Is it better to disconnect the load from the generator by unplugging it or shutting the generator down first. Probably best to turn off the load with breakers first, but I am lazy.
  • Unplug...but preferably NOT with a big load attached.
    The Honda 2000 manual says unplug first.
  • I know that a small amount of arcing at the plug happens when unplugging first.
  • Turn off any large or sensitive loads (such as electronics) first, then it really doesn't matter.
  • Start gen first, then plug in/ unplug first, then stop gen.
  • If the load is minimal, say the converter charging at a few amps
    Your ok to just shut off
    If it's a heavy charge rate, or the a/C is running, or the water heater on electric
    Unplug first
