dougrainer
Aug 30, 2018Nomad
bum4evr wrote:
I googled about how much power a motorhome fridge takes and here is what I read: "An absorption refrigerator uses heating elements that draw between 350 to 600 watts, depending on the size of the refrigerator, or about 10 times as much power as a conventional compressor driven refrigerator uses.Jan 29, 2010"
Not that I believe everything on the net, but it sounded reasonable.
Thanks for the advice - I guess I can just leave the switches on then.
Sean G
The largest RV refer has 2- 120 elements at 1.7 amps EACH. That is 3.4 amps at 410 watts total. BUT a RV refer will run LONGER to cool than a compressor type. So, yes, the RV refer will consume more power to do the job. Doug
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
