wa8yxm
Aug 30, 2018Explorer III
Image did not image.
However if that is an Intelletc panel the light means "12 volt system is live" it does not mean "Battery is connected"
What is the difference.. You said you are plugged in so the light is powered by the CONVERTER when you are pulgged in
Other systems.... I do not have but may work in like fashion.
If the switch is a 3-position spring return to center, as opposed to a toggle, Listen for a CLUNK somewhere .. ON a gasser under the hood is one spot. on all near the batteries It will CLUNK when the button is pushed. either way.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
