Old-Biscuit
Dec 31, 2013Explorer III
mena661 wrote:
Never knew this but I'm a RV newb still. Anyone have pictures on what to clean?
Check on-line for a manual that covers your brand/model of fridge.
It should have description/recommendation for routine maintenance
Or post your Brand/Model and someone will probably provide a link to the manual.
Generally
Clean/vacuum the backside area
Check for any fallen down insulation or obstructions that would disrupt the flow of air
Check wiring/connectors...clean/tight/any signs of overheating/burnt
Check burner area for rust/debris (I tap on flue to dislodge any junk and then clean out burner area if needed)
Check for any signs of water leaking in
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
