ToyHauler
Mar 31, 2016Explorer
pianotuna wrote:
Hi,
It would cost me a new inverter to move to 24 or 48 volts.
As it happens, the Magnum PT100 IS an MPPT unit, but that is not why I chose it. I chose it because it can handle 100 amps. It costs about $800. usd.ToyHauler wrote:
24 volts is more efficient than 12 volt and mppt gives an advantage over pwm significantly over lower voltages all the way. Its a win win no matter what your preference.
So I would argue over your lower voltage preference
Your being cheap
The benefits you get from higher voltage and the benifits from the amperage you get from the controllers. negates the cost. IE your being a cheap ass at a deficiency.
I have the very same inverter as you and I run 24v panels.
I see higher charge amps using the 24v than I ever did with 12 volt with as many watts per panel bank. Almost double in fact.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
