dougrainer
Feb 17, 2014Nomad
If your refer is in a slide room and the rear fans are inop, the refer will NOT operate at all. There is a big difference in operation on a 1200 series between installed in a slide room and having the top roof top vent. In a slide room, there is NO WAY to adequately remove the hot convection air when the fans fail. The GOOD news is this. IF you have the upper door, you can install a small 120 fan blowing out in that cavity to get the refer operating until you get the fans replaced. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
