Old-Biscuit
Feb 19, 2014Explorer III
dougrainer wrote:Old-Biscuit wrote:dougrainer wrote:
"Absorption fridges cool or don't----no in between (freezer cooling and food section not)"
Incorrect. A blocked cooling unit will still freeze the freezer and not cool the bottom. The blockage is AFTER the freezer coil sections on most cooling units. This is why some cannot believe they have a defective cooling unit. Doug
Just curious......
With blockage how can it continue to cool without flow which transfers the heat?
The Blockage(partial) is after the freezer coils and is enough to freeze the freezer and enough to inhibit the complete transfer of cold in the lower section. Very few have COMPLETE blockage. As I stated, when this happens, the RV'er cannot believe he has a defective cooling unit. Also, this was a very common scam selling used units. The seller would show the freezer frozen and the novice buyer thought the refer was working. THEN found out too late the had a $1000 plus problem. Doug
Thanks!
Always looking to gleam more info.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
