dougrainer
Feb 22, 2014Nomad
Starburst2 wrote:
I just posted with a similar problem. I did a search and it came up with 0 posts. Now I find this one with almost identical symptoms. What gives?????
Doug Rainer states that the blockage is as hard as a weld. If so, how can this suddenly occur? My refer is in my new Winnebago Sightseer less than 10 months old. The refer has worked well since new. I bought it in Mesa AZ and the temps were over 100 outside and the fridge worked great but it did not stand up to the Texas RGV temps in the 90's only a few months later. is this an indication of poor quality on Norcold's part or is it an aberration?
I would appreciate your comments as well Doug. I just posted about a half hour ago.
Regards,
Lloyd
The odds are you have NO blockage, You have a problem and you need to get it in to your dealer for evaluation and repair. They will FIX your refer, NOT replace it. Things malfunction, and this (your worry) is one of the problems with these Internet forums. You think you have a MAJOR problem, when in reality it is probably just a minor fix. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
