donn0128
Dec 03, 2016Explorer II
Removing microwaves is a straight foreword job. In the cupboard or cabinet above it you will find where it is plugged in. Unplug it. Next look, you will see two philips head screws on the floor or the cabinet. Remove them. Either have someone hold the microwave up or be prepared. They are heavy and akward. Once the screws are out, tip towards you to about 45 degrees and lift off the bracket.
