dougrainer
Dec 03, 2016Nomad
Most are mounted the same. You have the standard Stick home mount bolts you remove thru the underside vent filters. Then you have to remove the upper plastic vent grill and you will see 2 to 5 screws holding the top to the upper wood cabinet. Now, some models(very few), there will be a wood Fascia above the top of the M/W that pops out and you will see 2 "L" brackets holding the top. Doug
