dougrainer
Dec 06, 2016Nomad
gotsmart wrote:
Sharp install manual.
-There is a large metal mounting bracket that is secured to the wall.
-Inside the upper cabinet above the microwave there should be 2 screws near the front of the microwave - one on the left and one on the right. See step 8 on page 7 of the install manual. The microwave's case is set up for 2 mounting points to the upper cabinet, although, as others have stated, there may be additional screws that are securing the microwave's case to the upper cabinet as well.
-Removing the grills from the bottom of the microwave will reveal 2 long bolts that go up at a diagonal that hold the microwave to the metal mounting bracket.
While this is true for HOME installs, it does NOT take into account the extra screws RV makers MUST install to keep the Microwave from vibrating and breaking the wall mount off the wall. EVERY over the counter RV M/W I have removed and reinstalled in the past 20 years(HUNDREDS if not Thousands) ALL have those extra screws that will not be listed in the M/W install manual. Doug
