EMD360
May 10, 2021Explorer
So here are the wiring connections for my rig. First the not very helpful Renogy diagram. I suppose it gives the general operational idea.
This is my plan for the solenoid/isolator wiring.
The negative side of the charger input is grounded under the rig with other grounds.
On the coach battery connections i add a 60 amp breaker then wire that to the coach DC and the positive battery terminal. And then wire the negative directly to the negative terminal.
Edited to add charger connections.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
