NRALIFR
May 11, 2021Explorer
It looks like you’ve got the connections right. The only thing I’d say is to make sure the circuit lengths as short as possible. On the input side of the Renogy unit, the circuit length will likely be quite long which will induce a voltage drop. But, by using the recommended wire size, it will be able to draw the needed amperage through the bigger gauge wires so the unit can boost the voltage on the output side.
Hopefully you can place the Renogy charger very close to the batteries it is charging, and keep the circuit length on the output side as short as possible. Inducing voltage drop on the output side would defeat the purpose of the DC-DC charger.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
