EMD360
May 11, 2021Explorer
I’m actually thinking of screwing the charger to a piece of plywood fitted in the step battery compartment directly above the batteries. The solenoid is in the same compartment and I’m planning to use #2 wire. I was not planning to replace the wire from the chassis battery though. That would be a pain. I’m working on the wiring information for the progressive 9100 charger too. I’m not sure how close I can get it to the batteries. It’s actually not that far away at the WFCO converter about 4’. But I could reduce that if I figure out how to place it under the refrigerator. Still planning.
After reading about circuit breakers and ANL fuses, I decided a fuse was safer so I ordered a case and a couple of extra fuses. May never need to replace one but good to have.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
