Bionic_Man
Nov 02, 2014Explorer
Is what you are seeing in the holding tank liquid or solid? If solid, you have the "pyramid of poo". I had that a few years back. Removed the toilet, used one of those sewer snakes to break up some of it, then used Rid-x in the tank to take out the build up.
If it is liquid you are seeing, I would think that despite what you have done, the valve is not opening, or something (feminine hygiene product) is blocking the drain.
Good luck.
Good luck.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
