time2roll
Nov 02, 2014Nomad
Nothing comes out? Not even some liquid?
Are you sure when you pushed that hose 3' past the valve that was enough to get to the backside of the tank?
If you are brave enough to shove a running hose up the black drain you gotta go all the way until you see water movement from looking in the toilet.
I would be far more inclined to use a back flush fitting.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
