allen8106
Nov 03, 2014Explorer
RJsfishin wrote:
This didn't just happen, Sounds like it has been building up,.....maybe since new, draining off nothing but the water, while the solid was building up, and getting dryer all the time to where it is now a solid block. You need to just slowly break it up w/ a full flow water hose, from the bottom first, and if no good, do it from the top. One thing about it, if you are the normal, you'll get it, one way or another, and you'll never let it happen again.
I had it happen once in 45 yrs.
I've rinsed it with the tank flusher religiously because of the feedback I've read on here. I always rinse until it runs clear.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
