wa8yxm
Oct 16, 2017Explorer III
Get ye to an RV store or even a Wal*mart Auto dept
You will find hoses there. the female end of the hose is designed to hook to the STANDARD Rv outlet.. these are nearly always the same (There are a couple of exceptions but very high end and very rare)
The Ground end..... Multiple opeions here
One is a screw in I'd suggest a wrench to remove. You screw it into the ground socket and then push the elbow (Outlet end of the hose) in.
One has a handle on that screw in part.. I'm still a bit unsure on this I am using it but.. Well I've had one disaster already
One is a simple push in type.
I think one cam locks (But not sure)
I'd go with teh screw in and a wrench (It's a big plastic thing) if you can find it.. but if you can't
Check out the Tethford Sentenal.. The photos are all you need even if you do NOT buy the hose.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
