full_mosey
May 05, 2013Explorer
westend wrote:
There is little information to prove that AGM batteries will last any longer than FLA batteries in a very dynamic situation like an RV, where current draws are high relative to the capacities involved. Most of the anecdotal information I've read points to the FLA, larger plate batteries, like GC2 or larger deep cycle batteries garnering the longevity crown.
To be fair, running a fridge is not exactly a dynamic situation re comparing AGM to FLA. It is simply another low Amp draw that accumulates AHs over a long period. This is exactly the usage that gives a deep cycle FLA a decided advantage.
AGM does have the advantage whenever dynamic includes high wattage inverter draws. That is, draws that cause the deep cycle FLAs to sag and precludes desired use of the bank by the RVer.
Each RVer needs to choose the battery type that fits their style.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
