Tango424
Feb 20, 2024Explorer III
Dont forgert to check the max input amps and output amps on those batterys some of the bms's will omly allow yuo to charge at half the rated amp hours so say 100 ah might only charge at 50 and also make sure the bms will output 100AH some wont it will state that in the specs of the batteries
You might have 200 AH but can only use up to 100 AH but for a longer period of time
