bigfootford
Feb 24, 2024Nomad III
I recommend that you consider a Victron Smart shunt to go along with those Lbatts. The 712 is the best. I did get the gauge too but the phone app for it is very good and you can do without. Then you can keep track of the AH in and out of the batteries and the voltage status along with state of charge. You did not say that your new Ltime batteries are 12vdc but I am assuming they are.
You did not tell us the model of your WFCO converter. If it is an older non Lbatt compat it might not give you the boost mode due to the higher at rest and the differences in the voltage of these Lbatts.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
