2oldman wrote:
GordonThree wrote:
I seems to vary, there must be some other load on the circuit that's not static. Right now, it is 12.7. Earlier it was 13.2.
Thanks. Is the pump getting warm?
I'll check it more closely next chance I get. The clampmeter reads 6 amps, so the pump is running at ~60 watts, I expect the motor will get warm.
Regarding the other suggestion:
The pressure switch does not feel warm... if it were dropping 3 volts, at 6 amps that's 18 watts, it would be HOT. Haven't gotten a volt meter on it yet.
edit: fixed typo
