GordonThree's avatar
GordonThree
Upgrade water pump wiring?
Has anyone measured the voltage at their water pump while it's operating?
I'm seeing ~6 amp load and about 10 volts with the pump running wide open (multiple taps opened.)
Battery voltage is at 13.2, as provided by my temperature compensating charger (ambient = 80F)
A 3 volt drop seems high to me. Wiring to the pump is 14 gauge.
Thinking of putting in a dedicated 12 gauge run to the main fuse panel. No idea how many branches the wiring Elkhart put in has, or how many staples they put through it.
USCG / ABYC says max 10pct drop, but their charts show 14 gauge wiring is enough. Does RVIA have a similar standard. Do SAE standards apply, since an rv is considered automotive?
  • Voltage readings before and after the pump's pressure switch? At the fuse box with pump running.....?
    Indeed you need to determine WHERE the voltage drop is occurring.
  • 2oldman wrote:
    Are any parts of the circuit getting warm?
    Not that I can tell, but most of it's hidden under the floor and inside the walls.
    I will check the connections behind the fuse panel, maybe a loose wire nut?
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
