Bill_Satellite
Oct 13, 2018Explorer II
Generally, yes. If you are planning to run more stuff with the larger inverter you may need to add some battery capacity and hopefully, you are installing an inverter/charger to be able to recharge that larger battery bank.
Take a look at the installation instructions on line and compare it to your current installation. The run from the batteries to the inverter needs to be as short as possible and the cables may need to be replaced with thicker ones.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
