3_tons
Oct 13, 2018Explorer III
RLS7201 wrote:wa8yxm wrote:
Some Xantrex inverters (not all) can be "Throttled" down from their max to 1000 watts. Why would you want to do this? Well an 1800 watt throttled will run cooler and likely longer "Mean time between failures"
But normally if upgrading from 1KW to 1.8 you would need to upgrade all wires both 12 volt and 110 volt.. Else you need to limit it to 1000 watts. I suggest you do the limit. No more than 1100 watts with existing wires.
Can you give us a littler more on the throttling? I'd like to see if my Xantrex will throttle.
Thanks
Richard
Inverter Throttling, please clarify...
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
