pianotuna
Oct 17, 2018Nomad III
Mex,
Under the current administration they no longer export. They dump the waste into streams and rivers.
My reason for picking Victron is simple. The Magnum has 120 volt cooling fans. If you turn it off after it has been running a heavy load, there is no cooling. Then the insides catch on fire. I have the scorch marks on the wall to prove this.
I do not know if Victron uses 120 volt cooling fans, but I sure won't recommend Magnum. To be fair they did replace the unit. Leaving me to be CAREFUL how I use the thing.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
